10-30-2018 12:20 PM
You should start a new thread for your question, not add to the bottom of an old thread. It makes it hard for people to see.
When you say "Boolean variable" what exactly do you mean? An indicator? Control? Global variable?
10-30-2018 12:27 PM
Actually though, since you are already in this thread, if you just look at Alexander's example above, that pretty much shows you how you can do what you want. Change the value of your "boolean variable" however you need based on what it is (wire to the terminal, use a local variable/property node, etc...) and then have the "time target" based on the value of your numeric control and wait to go to the next state where you turn the boolean variable off again.
