Change captions of multiple items on Front Panel
Hi all,
I want to put Language function in my program by changing the captions programmatically, but it becomes annoying when there are many items to control (as attached picture). I have to create lots of property nodes one by one for all the items which I want to change the captions . Is there any easier way to do this?
Thanks for any help.
Ian
(2,970 Views)
Accepted by topic author IanYuan
Hi hsyuan,
Yes, sure!
Use a property of the pane(l) to get references of all controls in this pane(l)…
(2,944 Views)
Yes, sure!
And also get the references from all pages in each tabcontrol, and each control in each cluster. That's where recursion comes in handy (you can have clusters in clusters in pages etc.).
(2,922 Views)
MGI has a VI called "Get VI Control Ref[]".  It returns an array of control refs, including controls found within a tab control.  If it sees a cluster, it returns the cluster ref but not the controls inside the cluster.  You should be able to use this VI as a starting point and add some functionality for clusters, if necessary.
Edit - Don't modify the MGI version, but that should go without saying.
aputman
Heads up! NI has moved LabVIEW to a mandatory SaaS subscription policy, along with a big price increase. Make your voice heard.
(2,902 Views)
GerdW 已寫:
Hi hsyuan,
Yes, sure!
Hi GredW,
Sorry I am a new hand in LV and can't figure out how to do this. Is there any detailed document or link that I can read for reference? It'll be great if sample code is available. Thanks for your reply!
Ian
(2,883 Views)
