Changing cluster values on the fly
This is just test code to get a basic understanding of how things could work.
But yes, I definitely should change my username to Rube Goldberg
Message 11 of 16
(800 Views)
And I called it by static reference from a different loop because I didn't want it to stop the main loop. I want a popup window to happen
Message 12 of 16
(800 Views)
Alright. I think this is the solution
MAIN VI
SUBVI
Message 13 of 16
(792 Views)
That makes no sense. Since it is a different loop, it won't block the other loop.
See if this can give you some ideas.
Message 14 of 16
(788 Views)
Ok but, if I did it your way, I would have to get that cluster data back to the other loop somehow. Because like I stated before, there will be a TCP connection that will transfer that new updated cluster data to the server
Message 15 of 16
(785 Views)
This code is just "your code", but cleaned up.
Why can't you do the TCP transfer in the event loop?
I assume you only want to send the new values over the network when they change, right?
If other things need to happen, you need to give all requirements!
LabVIEW has plenty of ways to communicate across loops. Once we know the details, we can suggest a solution.
Message 16 of 16
(776 Views)
