Combiation of 4 goups of numbers and each group containing 2 numbers
Do you have an example using the lower code? I couldn't figure out where the i value came from?
Message 11 of 15
(625 Views)
i is the iteration that you are interested in.
Simply make the input list = [9,9,9,9,9,9,9,9,9] since you have 9 arrays of length 9.  Each iteration will return the 9 indices for the current iteration, i=0..387420488 (9^9 = 387420489).
Message 12 of 15
(614 Views)
I figured out how that code works, and managed to make it work inside my Keyence XG-7000 vision controller. I'm looking for a way to summarize the filter combinations that read 2D matrix codes for poor images inside the vision controller. I added some code to count the random True results by cartesian indices.
Message 13 of 15
(598 Views)
I know this is from a long time ago, but your comment is the only thing that Google came up with when I searched "XG" and "LabVIEW".
unclebump, do you have any VIs that you could share that you used to control your XG-7000? I just inherited a project from another engineer and all of her source code has mysteriously disappeared.
Any help would be appreciated!
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
Message 14 of 15
(534 Views)
No, I have never controlled the XG-7000 thru Labview
Message 15 of 15
(508 Views)
