11-26-2009 12:08 AM
Combox Box is used to enter data in run time. "Allow Undefined Strings" option enabled.
Enter a data: "Abcde", it is stored to the list.
Enter another data: "ABcde" labview takes this data as "Abcde", its not recognizing the case sensitive characters.
Any suggestions or solutions to over come this problem.
Solved! Go to Solution.
11-26-2009 12:35 AM
Do you want something like this?
Regards
Shrek
11-26-2009 06:41 AM
shrekt's reply illustrates the problem...
The solution is to make a property node on the combo box, select CaseSensitivePopup, and set it to true.
Rod.
11-26-2009 09:34 PM
Yes Shrek, Rod this is the problem am facing.
Thanks a lot it works fine now .
11-26-2009 09:46 PM
Shrek,
The problem is the same but its in runtime entry of items, instead of adding items by "edit items"(static).
Setting the property node to TRUE solves the issue.
Arvinth
11-26-2009 10:03 PM
All,
Message 3 of 5 is the actual solution, unknowingly marked 5 of 5.
Arvinth
11-27-2009 07:07 AM
Hi Arvinth,
You could always "unmark" the post marked as the solution, then set the correct one
....and clicking on the Kudos star is always welcome
Rod.
