Compiler error. Report to NI Tech Support: ufppushop err, c=0xF1
When saving/runing a vi that performs some calculations in a formula node containing several if's and a switch statement. (LV6.1, WinNT)
(2,954 Views)
Accepted by topic author Technico
I've solved the problem: the compiler error occurred because one input of the formula node was an enum.
When inserting a cast to numeric, the problem was solved.
(2,954 Views)
hi
i am also getting similar type of error while executing my vi.
if possible can you please suggest a solution for the attached vi.
thank you
(2,451 Views)
