Config write key outputs data in Notepad++ with equal to sign
I have a situation where I am trying to write data in Notepad++ using Write key VI in labview library.
The probelm here is when we wire something to "value", it writes it with double quotes and if is it blank than it writes with =" ". Just to clear it "Class" and "Jammer Input MB/HB BPF" goes to the "key" wire.
I dont understand how to get rid of those quotes and equal sign.
(3,223 Views)
You can't do it using the config file VIs. Those VIs write a specific format of key/value pairs, separated by an equals sign, with quotes around strings.
(3,203 Views)
That is standard for ini files as far as I know.  I don't know if it's still true, but before, reading an implied string (no quotes) that had a space in it tripped up the reader.  Or something like that.
Bill
CLD
(Mid-Level minion.)
(3,189 Views)
Strings are usually written with citation marks to handle spaces. You can deactivate that by wiring True to "write raw string".
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,150 Views)
/Y
I forgot all about that, since I haven't ever cared how it went in or came out.  Nice.
Bill
CLD
(Mid-Level minion.)
(3,134 Views)
