Consultation of VI
Hello! I am starting to study Labview and I ask for help to know where I can find these two VI. Thank you.
Message 1 of 17
(1,467 Views)
Is this from some website where you only see the code as image? Hard to say if these are even part of LV.
Message 2 of 17
(1,454 Views)
I must reproduce this diagram from the attached image but there are two VIs that I don't identify
Message 3 of 17
(1,444 Views)
ctrl + H opens context help
Hover the vi to get the name.
ctrl + space
This will let you quick drop a vi by name
Message 4 of 17
(1,440 Views)
I have already done this, however I do not identify the VI
Message 5 of 17
(1,426 Views)
What do you get when you hover the VI?
Can you add your vi that contains the objects you want identifying?
Message 6 of 17
(1,391 Views)
I want to calculate the power p(t) and the active power of a load with:
v(t)=138 sin(377t)
i(t)=13 sin(377t-30)
Message 7 of 17
(1,368 Views)
So what have you got so far?
Assuming this is homework, I guess they want you to make a sub vi
Message 8 of 17
(1,364 Views)
If I can identify the VIs that are in the red box of the attached image, I could move forward.
Message 9 of 17
(1,357 Views)
I believe that to be what the assignment is. Create the sub vi highlighted in red on the left to multiply the two waveforms.
Inside that vi I assume there is one input for v(t)=138 sin(377t) and a second for i(t)=13 sin(377t-30)
Create a vi that performs those calculations.
Message 10 of 17
(1,350 Views)
