11-14-2014 04:00 AM
This is my first time in using LabView and I want to control the E3631A power supply remotely using the instrument driver. I have downloaded the driver from this website http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=0475216F9FCA5335E0440003BA7CCD...
Basically there are two different excel files for the two output channels (+6V and +25V). I am currently trying to use the two output channels to step through the voltage defined in excel files every second. I am able to extract the data from excel, but my problem now is that I am not sure on how to control the two channels simultaneously. Could anyone please help me solve this problem?
Thank you.
Solved! Go to Solution.
11-14-2014 07:05 AM
Just use the Configure Output VI in the drivers to set each supply individually.
11-18-2014 03:04 AM
Thank you for the help crossrulz! I have managed to controlled the power supply as I want now.
