11-30-2023 10:49 AM
@Intaris, I see the interest of the "Reinterpret Number" FPGA Node, but in the present case you have to change sizes anyway (24bit <-> 32bit) to comply with the chosen FIFO type. But I agree that FXP representation of constants / controls / node outputs are not visible at all. LabVIEW FPGA could be improved if we had the possibility to make it visible on the block diagram directly.
11-30-2023 10:56 AM
Out of curiosity, where do you see the conversion from 24-bit to 32 and back? I've re-read this thread and the other you've linked to and see no mention of changes in bit width. Is this just familiarity with the device?
11-30-2023 11:27 AM
12-01-2023 05:36 AM
Hi Raphael,
First test has shown this solution works 😊
Thank You for support.
P.s I promise not to multiply threads if further doubts around this matter arise.
