Converting a VI from LabView 7.1 down to LabView 5.1
Can anyone help me converting a VI from LabView 7.1 down to LabView 5.1
Format date/time i 5.1 does not support weeks in new millenium
In LabView 5.1 i get that the first week in 2006 i week 52. But the format date/time in LabView 7.1 works fine.
Message 1 of 12
(3,702 Views)
Am I right in understanding you want to convert to a version whioch does NOT work properly?
I can't do it, but I'm sure someone will.
However, bear in mind that some functions are not available in LV 5.1 which are in 7.1.  I can't open your VI, so I don't actually know what's in your VI.
May I ask why you want to convert to a non-working version?
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
Message 2 of 12
(3,691 Views)
I assume that the aim it to obtain a function that does the same as the veek.vi (see pict of diagram attached) in LabVIEW 5.1
Am I right ?
I think the TimeStamp function used here doesn't exist in LV 5.1, anybody can confirm ??
Personnaly I don't have LV 5.1 installed so I can't help, but certainly somebody will.
Epictetus
Antoine Chalons
Message 3 of 12
(3,690 Views)
I want to convert because some of our test are still running on LV5.1
We have encountered the problem with extracting the week number from the Windows time.
My new VI i made the same way i LV 7.1 as it was i LV 5.1, but the function Format date/time string works in LV 7.1
I use the component Get Date/Time In Seconds and Format Date/Time Strint with format date/time string %W
Message 4 of 12
(3,685 Views)
That is correct.
It works in LV 7.1 but not in LV 5.1
Message 5 of 12
(3,683 Views)
I'm not sure what you are talking about. Opening that VI both in LabVIEW 7.1 and 5.1 (I recreated it for 5.1 as simple as it is) gives me in both cases 01 as result.
So what are you trying to say here?
Rolf Kalbermatter
Message Edited by rolfk on 01-06-2006 02:33 PM
Rolf Kalbermatter
My Blog
Message 6 of 12
(3,685 Views)
I've done the same vi (your week.vi in LV 7.1) in LV 5.1 and it works...
do you want me to send it to you ??
Message 7 of 12
(3,674 Views)
alli esta...
is it what you need ?
is it really not working on your computer ?
on mine it give 01...
Message 8 of 12
(3,670 Views)
Yes. That would be nice.
Message 9 of 12
(3,663 Views)
how comes the messages are not in the right order ???
the VI posted by DaviZ has been posted before he asked if he should upload it Smiley Surprised
Epictetus
Antoine Chalons
Message 10 of 12
(3,660 Views)
