Converting column of Dates
I'm working to figure this out on my own but in the XY graph why can't I only add 2 traces beyond the time stamped axis?
Message 11 of 14
(358 Views)
Hi LED,
which kind of cluster do you want to create for the XY graph? Does the XYgraph accept your kind of cluster?
In your last image you create a cluster representing a single plot for that graph.
I told you to create "an array of plots", but I don't see any array-related function (like BuildArray) in your image.
You also got the recommendation to read the (context) help for XYgraphs to learn how to create an array of plots.
It seems you don't listen (well) to recommendations/suggestions…
Message 12 of 14
(355 Views)
No I don't listen very well, but I just got the answer out of you- so thank you!  😎
Message 13 of 14
(351 Views)
Thanks !
Message 14 of 14
(338 Views)
