Correspond motor positions with time in APT motor controller incorporated in LabVIEW
Hey there
I'm using Labview to control a stepper motor from Thorlabs. I want to apply a tangential movement in my system. This movement should be controlled regarding traveled distance, velocity and acceleration. I was able to do such controls. Additionally, I'd like to correspond motor positions with time to generate a graph/chart, when I set a distance of movement. I couldn't do that as I've not found a way to export motor positions from the APT interface in LabView.
To aid my explanation, I made a simplified version of my code and is attached. Its name is "saad_simplified_version". The file is compressed with other VIs downloaded from Thorlabs website regarding motor control.
Additionally, I took a short video of the APT interface in Labview which is as well found in the compressed file. As you can see in the video, I highlighted the values that I need to be exported to a waveform graph/chart. These values are different positions of the motor that have been covered when I set a distance of movement (the motor moved from position 1 to 3). I need to take these values and correspond them with time to generate a graph/chart. Would it be possible to export such values?
OS: Windows 10
Software: LabView Professional Development System (2017-32bit)
The stepper motor used is LNR50S/M - 50 mm (1.97") TravelMax Translation Stage, M6 Taps
The controller is BSC202 - Two-Channel APT™ Benchtop Stepper Motor Controller
Saad
(2,442 Views)
Hey Saad,
Typically property and invoke nodes can be used to access specific values from front panel controls or indicators. Is this an option?
I don't have the APT interface so am unable to test this.
It may also be worthwhile contacting Thorlabs for information on this control.
Best,
-Jelmer
(2,393 Views)
Hi JelmerD
Thanks for replying.
Yeah, I know that there should be a way to use property/invoke nodes to get these values. However, after reading description of the methods (these methods can be applied by invoke nodes) programmed by Thorlabs, I haven't found what I want to achieve. I contacted engineers in National Instruments and Thorlabs in the last two weeks. They tried to help, but unfortunately we were unable to to find a solution. So, I thought I might find a solution if I post this in the Discussion forum. Hopefully, I'll find a way to achieve my goal soon.
Saad
(2,384 Views)
