Count number of times an analog input happens?
Seems that decreasing the 'wait' in the loop helps.
Would there be any benefit to making this into a subvi to run in a larger loop?
___________________________________________________________________
Still confused after 8 years.
Message 11 of 19
(817 Views)
Hi Ralph,
- your loop timing determines the sampling speed. You cannot detect pulses with lower switch time than your sampling time. Fundamental data aquisition knowledge...
- you can put that into a subVI. That doesn't change the behaviour, but makes the (main VI) block diagram nicer Smiley Wink
Message 12 of 19
(812 Views)
In use as a subvi, one wouldn't want a while loop, would you?
If not, how do you handle the shift registers...  Make them inputs and outputs of the subvi and run them through the main loop?
Message 13 of 19
(809 Views)
Hi Ralph,
you can do your task without shift registers: use feedback nodes instead 🙂
When you create a subVI you should think/learn about reentrancy and it's (ab-)uses!
Message 14 of 19
(807 Views)
Oh neat.
I'm a hack so all help is appreciated.
Message 15 of 19
(801 Views)
Hmm.
Made it into a sub, trying to run two separate instances and they're behaving oddly.  Just running away and no distinct control.  Do I need to add error in and out to 'sequence' the subvis?
Message 16 of 19
(802 Views)
Hi Ralph,
did you read that last sentence of message #14? It's important and I wrote it for a reason...
You really should know what you're doing when you create programs. RTFM! Learn the basics!
Message 17 of 19
(795 Views)
I took all three courses five years ago and knew everything pretty well then, it's been a couple of years.
If I don't ask, how will I know?
Message 18 of 19
(790 Views)
OK, I set the Execution properties for the sub vi to Reentrant with preallocate for each clone and the functionality seems to be there.
Glad I had this conversation, because I have some VI's with multiple calls of the same vi that are very, very large and I had been using the error handler to sequence the subvi's.  This was causing some major slowness in the operation.  As a result of this conversation, I believe I can go fix things that have been bothering me for years.
The classes didn't really cover reentrancy.  This is all new to me.  Thanks.
Message 19 of 19
(787 Views)
