Counting a HIGH signal
Hi.
I am continuously reading a digital input signal in a while loop. My application consists of a normally open switch that when closed the input is a high. I would like to increment a counter to track each time the switch is closed. The problem is since the switch is mechanical, the counter increments more than once before it is actually released. How do I code it so that when I get a high I increment only once and increment another only on the next high and so on?
Thank you in advance
(3,126 Views)
Hi.
(3,128 Views)
Accepted by topic author LNH02
You can use this VI to define the direction of crossing you are looking for:
http://zone.ni.com/reference/en-XX/help/371361H-01/ptbypt/boolean_crossing_ptbypt/
(3,123 Views)
Gregoryj,
Many thanks!!
(3,078 Views)
