Create a selector from an array of paths
Hi all, LV beginner here,
I'm doing a program (VI) that receive an 1D array of paths and returns an 1D array with the selected paths/elements that i want to choose from that 1D array that i input previously.
I want a control where i can select the elements that i want to return from the full list of paths.
I' trying different ways but i don't know how to do it.
Im working with LV v17.
Thank in advance.
Message 1 of 8
(765 Views)
I attach the files.
Message 2 of 8
(763 Views)
If your question is related to GUI, then may be ListBox is what you needed:
with appropriate selection mode of course:
Message 3 of 8
(754 Views)
Thank u, i think that the Listbox is what i was looking for.
But what i want is that from the array that i put at the beginning, select some elements or all of them (this would be another control i guess) and then with a button load them (i exit from the while loop with this control and the previous one), and then take the selected elements to the Open VI Reference.
Message 4 of 8
(730 Views)
That's basically what was posted. Just connect the Selected files to Open VI ref.
Qestit Systems
Certified-LabVIEW-Developer
Message 5 of 8
(687 Views)
Accepted by topic author xespizua
Then you can use it like this:
By the way - you don't need to wire "N" Input of the for loop for autoindexing - this will iterate in this particular over all array elements anyway.
Message 6 of 8
(668 Views)
When I want to present a list of files, I use a MultiColumn Listbox, putting the folder in the 1st column, and the filename in the 2nd column.
Message 7 of 8
(658 Views)
Thank u for all the solutions, in the end i picked the Andrey's one, although i also tried with Paul's and it also seemed that it could work, but i opted for Andrey's bc it was more what i was looking for.
Message 8 of 8
(619 Views)
