10-18-2010 09:09 PM
Hi everyone,
I am trying to realize retriggerable analog data acquisition on PCI-6110, but meet with the error 50103 "The Specified Resource is Reserved". I would really appreciate if someone could tell me how to avoid this error in my case.
Brief description of my code is below:
1. Use the freqout to generate a fast continuous pulse train as a clock signal.
2. Divide the frequency of this clock signal and generate a slower continuous pulse train, which is called LSYNC.
3. Use LSYNC as a trigger. At each falling edge of LSYNC, generate a finite pulse train, which is used as the sampling clock source for analog DAQ.
The code is attached. Thank you very much.
Hall
10-20-2010 01:55 PM
Dear hallwang
You will get this error when you are trying to access a resource that is already being used by another application. Make sure that you are not accessing any of your channels on another VI or a Test Panel.
10-20-2010 03:27 PM
Thank you, Efrain. I learn that the finite retriggerable pulse train uses two counters, which already reserves all the counters on the board. That's the reason I could not generate the other two pulse train. I decide to introduce another DAQ board to generate these pulse trains.
