DO/AO sync signals not working when changing port/line of DO
Hello!
I'm a novice and I'm using a PCI 6251. I can't understand why this DO/AO VI only works when the DO line is set to port0/line0.
I have 4 lasers TTL connected to different ports (and diff channels) 0.0, 1.2, 1.3, 2.4, and a galvo control on the AO, moved buy a sawtooth waveform (points in the "output array"). I want the laser to be on when the ramp is rising and off when it's falling. I have an array of 1/0 values to be fed to the DO. Both arrays have the same number of samples.
For some reason I can't understand, the VI only works when the DO is on port0/line0, while when connected to the other lines doesn't.
Any suggestions on the reasons this is happening?
I was following this example:  https://forums.ni.com/t5/Example-Code/Synchronizing-Analog-Output-and-Digital-Output-Signals-Using/t...
(2,320 Views)
NI 6251 only supports digital waveform on Port 0. You need to assign all 4 TTL channels to P0.
From NI 6251 Device Specifications
Control Lead | Intelline Inc
(2,300 Views)
Hello and thank you for your reply!
I also tried to move one laser to P0.1, but it didn't work 😞
(2,297 Views)
Accepted by topic author Nidhogg
Did you test only one line at a time or assign P0.1 to another task while P0.0 is still running?
You cannot have more than one hardware-timed digital input task. You need to assign all P0.0 to P0.3 to a single task using NI-DAQmx Syntax for Specifying Physical Channel Strings
(2,276 Views)
Thank you! I think I fixed it now!!!!
(2,268 Views)
