05-16-2024 08:41 PM
In device manager my simulator has no driver
I try to search the CD that came with and nothing
I try to search the download i got from NI and nothing
I can not configure with the wizard
Solved! Go to Solution.
05-18-2024 03:43 PM
I also tried the Driver Finder
when selecting start using this driver it showed
I went back and installed the next one nidevsim_2.0 Instrument driver
i checked device manager and ni max which both said my device had no driver
with device manager i tried searching
C:\Program Files (x86)\National Instruments\LabVIEW 2015\instr.lib\NI Instrument Simulator
which was just installed and got nothing (same for search atomically for drivers)
i went back to driver finder and said install to overwrite existing files
repeated the process searching with device manager and still nothing
can someone help with what I need to do to use this device?
05-24-2024 07:12 PM
I wanted to follow up and check if I have this posted to the correct area?
05-30-2024 07:59 PM
any suggestions to try would be welcome
06-06-2024 09:00 PM
following up again
06-07-2024 10:28 AM
Maybe you just need the GPIB driver? I don't know a lot about NI Simulation but here is the GPIB driver.
NI-488.2 Download - NI
06-07-2024 04:18 PM
Should I get the latest or closest to my labVIEW version?
06-07-2024 04:41 PM
Driver support is for the matching LabVIEW version plus the 3 before it.
So if you are using LabVIEW 2021 through 2024, you can get the 2024 GPIB drivers.
But if you're using LabVIEW 2015, which is my best guess based on screenshots, then you want to get the drivers from no later than 2018.
06-20-2024 08:22 PM
(sorry for the delay)
I installed the driver you suggested:
and now it shows up good in device manager
also in NI MAX
and the simulation software sees it
THANK YOU!!!!!!!!
