Decimate an array to a fixed length
Hello
I am plotting some data in 3D and is rather slow... so I am trying to decimate an array to a fixed length (I know the decimate function, it's not that simple) :
If I have an array of length N and want to decimate to an array of length M (both N and M are decided at runtime). I made something like this, I am wondering if you have a better way.
It's not that important, this thing works for me, but just wondering if there is a better way.
Message 1 of 11
(1,266 Views)
Hi nitad,
  • You only need to divide once before the loop.
  • You can index the array elements inside your own loop so you don't need that additional green function with its own loop inside…
Message 2 of 11
(1,262 Views)
Hi
The divide in the loop is a rookie mistake,... but I don't get your second comment. I want to delete those indexes (or should I do it the other way around ? I mean I could use a conditional indexer, I was thinking this is slow).
(well, slow, is maybe not that important but the "array in" has typically 2k to 10k length, each element is a cluster with 5 to 10 arrays of 100 to 500 doubles...)
thanks
Message 3 of 11
(1,252 Views)
Hi nitad,
I don't use those green functions (OpenG? GPower?) so I cannot comment in their purpose just from looking at the image.
When I "decimate" an array I typically pick the elements that should remain instead of deleting all other elements - should be more performant when the decimation factor is >>1…
Your "array in" is a 1D array of I32 values according to the image!? No clusters, no DBLs…
Message 4 of 11
(1,236 Views)
Hi
I put a simplified version, here is a real life vi
it takes 27 msec on my computer (the green stuff is openG)
Message 5 of 11
(1,225 Views)
Hi nitad,
mind to share the VI downconverted to LV2019?
Message 6 of 11
(1,219 Views)
Hi
Here it is in 2019
A simpler version without OpenG (11 msec now), Vi attached.
Message 7 of 11
(1,213 Views)
"Delete from array" should never be inside a tight loop! I'll have a look.
Message 8 of 11
(1,199 Views)
Accepted by nitad54449
Hi nitad,
so you want to pick 200 elements out of ~3700 elements, so the solution is to delete ~3500 elements from the array?
I repeat: I would just pick the elements I need:
You may use a different rounding (or no rounding at all as ToI32 will also round)…
Message 9 of 11
(1,195 Views)
Hi
Nice, this Ramp stuff..
Now is in the msec range !
Message 10 of 11
(1,186 Views)
