Detect connection between pins using digital I/O
Thanks for the help!  I guess the 2012 and 2014 versions of those VIs look different.  I am using the VIs that you said they were but I am getting the same error no matter what I put in the I/O constant.  Both the VI as I have constructed it and the error message I am getting are attached below.  Is there some obvious mistake I am making?
Message 11 of 15
(1,240 Views)
My Bad!
This should fix you up.
That function between delete from array and create Task (Digital Input) is "Join Strings.vi"  Find it in "Hidden Gems"  or in <LabVIEW>\vi.lib\AdvancedString\
"Should be" isn't "Is" -Jay
Message 12 of 15
(1,181 Views)
Thanks again so much for helping to walk me through this!  I made the changes you showed but there is now an error coming up as soon as the VI reaches the Read task.  The error I get and layout of my VI are attached below.
Message 13 of 15
(1,159 Views)
Odd,
Try sticking in this hack for troubleshooting (I really only have a simulated device here)
Message 14 of 15
(1,146 Views)
Thank you for being patient with me.  When I add the DAQmx Task Property Node as shown in your last comment, I get Error -200088 that occurs at argument 1 of the property node with the possible reason for error being "Task specified is invalid or does not exist".  Is it possible for you to attach a snippet in version LV2012 so that I can see if it runs without error on the physical DAQ?
Message 15 of 15
(1,122 Views)
