Device not detected in MAX
I have an ethernet connected device that I can ping in the CMD window but NI MAX says that it is not present...
How do I get NI MAX to detect this device as Present?
What am I missing?
Message 1 of 9
(9,488 Views)
Check the below link. This might help. http://digital.ni.com/public.nsf/allkb/ABE4BC247E8AC9BC8625734E005CAB42
phani srikanth
Message 2 of 9
(9,478 Views)
I'm going to ask a basic IT question (questions that you're like... yes, I already did that).  Did you verify that that IP address is not being used by something else?  Unplug and ping?
Message 3 of 9
(9,466 Views)
What is the device that you are trying to connect to?
A NI device ?
Message 4 of 9
(9,430 Views)
Yes the device times out when I disconnect from it and ping then device.
Thanks for the response
Message 5 of 9
(9,299 Views)
 NI device ?
It is a custom amplifier designed by the company that I work for. This device can be communicated to by some utility software
but I wish to automate this with Labview.  Because this is an ethernet device, it does not sow up in Windows 7 Device manager
and more importantly, it is not found in MAX.
The MAX screen shown below states that it is a TCP/IP VXI-11 Instrument. I know that it is a TCP/IP device but am not sure what a
VXI-11 instrument is...
Do I need some special driver for MAX to see this device?
Thanks again
Message 6 of 9
(9,290 Views)
Accepted by topic author robojeff
If the instrument's firmware does not implement the VXI-11 or the LXI standard, it will not be detected as one. You should try using the :RAW type of connection instead of :INSTR.
Message 7 of 9
(9,273 Views)
Thanks Dennis...
How do I use a ":RAW type of connection"?
Message 8 of 9
(9,235 Views)
Got- Thanks Dennis
Message 9 of 9
(9,227 Views)
