05-24-2012 05:27 AM
Hello everyone,
I am new to labview.
I want to use USB 6211 as a DC power supply.
In DAQ assistant setting, I can choose "1 sample (on demand)" and " continuous with a while loop".
I found that USB 6211 would output voltage continuously in both case.
Is there any difference between them?
05-24-2012 02:08 PM
How much current do you think you need ??
You can ONLY draw max 2 mA from each channel. That is hardly a DC power supply.
The USB 6211 is only for signal generation and reading, not for power generation.
05-24-2012 07:54 PM
Sorry, not a power supply but only a control voltage generator.
I do not know how much current I need.
Actually, I want to you use α USB 6211 to generate a control voltage to a PMT module.
The voltage range should be 0.5-1.1 V, and the input impedance is 1MΩ.
Here is the specification of the PMT module.
http://jp.hamamatsu.com/resources/products/etd/pdf/m-h10722e.pdf
