Disorder when using FPGA to save data to TDMS
Hi everyone,
I meet a strange thing when using FPGA to log data to disk. I use 4 channels and use TDMS to save data. I use 4 different charts to observe each channel and no thing wrong. But when I check the data saved in TDMS, they are not saved in the order they are supposed to be. Each column in the TDMS should represent 1 signla from one channel, but the result shows the data seems fill in one column then another. I just can't understand how it becomes like that. I attached some pictures for your information.
The data from the FIFO.read should be 1 D array, right? So when it passes through the "Array Shape" in my VI, it should become a 4 column 2D array. Each column represents the data from each channel. I don't see any problem with this Vi. Why the data in TDMS is not saved in the correct way?
(3,109 Views)
The VIs are attached here
(3,107 Views)
Accepted by topic author iyearning
I think you just need to flip your dimention sizes.  The number of rows should be 500 and your number of columns should be 4.
GCentral
(3,088 Views)
Yes, you are quite right! I changed the row and column number and it works well now!
Thank you very much!
(3,070 Views)
