02-08-2018 07:52 AM
Hello All,
I am trying to plot the temperature values directly on the intensity graph instead of having a separate array as shown.
Is there an option or a way to do this ? Please Advise
Atif
02-08-2018 08:22 AM
02-08-2018 08:43 AM - edited 02-08-2018 08:47 AM
Hi GerdW,
Please see the attached screen capture, I might be saying it wrong.
But that is what i want to do, that temperature value you see on top i want it to be printed on the intensity graph (in real time).
Is that possible ? Please Advise
Atif
02-08-2018 09:20 AM - edited 02-08-2018 09:21 AM
Hi Aaatif,
several options:
- make the numeric array transparent (both the element and the array container). Then put it in front of your intensity graph to have the numbers in front of the colors
- fake the intensity graph by using colorboxes: use the same approach as before and put a numeric indicator in front of a colorbox (one per array element)
- draw the numbers into a 2D picture, then use that image as "front image" of the intensity graph (see it's property nodes!)
- use annotations of the graph to "draw" the numbers at the right position
02-09-2018 02:59 AM
Hi GerdW,
Thank you on your advise and patience to type so many options for me, would try one of these and keep you updated if i succeeded.
Best Regards,
Atif.
02-14-2018 07:13 AM - edited 02-14-2018 07:23 AM
Hi GerdW,
Using this - - make the numeric array transparent (both the element and the array container). Then put it in front of your intensity graph to have the numbers in front of the colors.
I got the concept of making the 2D array transparent, How does on put (overlay) it in front of the intensity graph?
Attached is what i tried .vi
Atif
02-14-2018 07:30 AM
Hi Aaatif,
You only made the array element transparent, but not the array container itself.
Did this for you…
You set the numeric array to front, then you move it over the intensity graph…
See attachment.
02-14-2018 09:08 AM
Hi GerdW,
Thank you so much .. that did it ..
Will attach the final .vi below it could help some one out too.
Best Regards
Aatif
