04-10-2023 11:51 AM
I have LV2021 32bit with the FPGA Module 2021 installed.
Every time I drag & drop an FPGA item (FIFO, Memory, Handshake, Register, IO…) from the project explorer to a diagram, LV hangs forever (at least 15min) and I have to kill it.
I expect it to create a method node with the default action depending on the item type, but it fails miserably.
Could that be a bug of the FPGA Module? How can I fix that?
Raphaël.
04-10-2023 02:08 PM
I have not experienced this, could you post code so others can try to replicate?
Otherwise you can reach out to NI support and they will provide feedback or a bug report.
04-10-2023 03:07 PM
04-11-2023 12:32 PM
Tried on the same configuration and am not getting any issues.
04-11-2023 01:53 PM
I also tried with LabVIEW 2021 SP1 (32-bit), connected to a myRIO (which shows up in MAX). Had no problems getting a new FPGA and populating it with random Controls, Indicators, and FPGA I/O ports.
