Driver for Keithley 2303
i just downloaded the driver for the"Keithley 2303 Voltage Source". But after unzipping and installing i did not see any ".vi"-files that i could use. Can you tell me where i can find a proper driver ?
Thanks a lot, heinzmann.
(2,869 Views)
Did you download that driver from here: http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E3B19B3E93E6659CE034080020E748... ?
That's an IVI driver. Have you installed the IVI Compliance Package?
(2,854 Views)
Yes, this is exactly the location i downloaded the driver from. I just installed the IVI compliance package. But what shall i do now ?
(2,834 Views)
I would suggest you check the links on the Instrument Driver Network that explain what a driver is and how to use one. Since you are trying to use an IVI driver, there are some setups that you should do in MAX. After that, try running the example that gets installed with the driver. It's on the Application Function palette of the driver (Instrument I/O>Keithely 2303x and 2304A).
(2,825 Views)
