Duplicate filenames during built
i´m trying to build an exe-file from by project. This is working but after the build i get this error-message:
So it reads as if the same filename is duplicate in the "NIReport.llb".
But: I don´t have this file in the specified directory and i also dont use any of the vi´s.
What does this error mean and what should i do?
Thank you for the help
(2,201 Views)
this is a known issue and is reported in the following Knowledgebase:
Building an EXE in LabVIEW 8.6 using the Report Generation Toolkit
http://digital.ni.com/public.nsf/allkb/2AE85CF95217E60786257540000D818C
Aou can also have a look in the following forum posts:
http://forums.ni.com/t5/LabVIEW/LabView-8-6-Installer-Build-Unsuccessful-quot-Error-in-action/m-p/77...
http://forums.ni.com/t5/LabVIEW/build-installer-error-help/m-p/783191?requireLogin=False
You said, you don't use Report Generation VI's. Maybe you are using VI's with dependencies to the Report Generation Toolkit?
You could post your project, so that I can have a look at it.
Best Regards,
Matteo
NI Germany
(2,116 Views)
