During build of exe some folder is not coming after build
When I build exe two folder (With name-Tests and Texts File)  is coming missing , I have select these folder into always include but it is not coming after completing build file or in preview file also.
Message 1 of 14
(1,837 Views)
Accepted by topic author Poojaavi123
Do you wanted to add this files in Data folder or in some designated Folder like "C/Project/Config"?
Message 2 of 14
(1,830 Views)
LabVIEW Application Builder does not copy empty folders to the destination. They must contain at least 1 file.
Alternatively, you could create a post-build action that automatically creates the folders if they don't exist in the destination folder.
Message 3 of 14
(1,824 Views)
Folder should come separate like data folder LV Classes these two folder should also come in same path.
Message 4 of 14
(1,821 Views)
Explore Destinations in the Installer Properties
Message 5 of 14
(1,809 Views)
but I need this folder in build file also, is there any possiblity.
Message 6 of 14
(1,798 Views)
what do you mean by build file? Exe?
If you create an installer and when you install all your required folders/files will be created/Copied in the respective file path.
Message 7 of 14
(1,778 Views)
@Poojaavi123
Have you read my comment ?
It does not work if your original folders are empty.
Also, you must create dedicated destination folders (in the "Destination" tab) and set the destination for the items contained in the folders (in the "Source File Settings" tab).
Message 8 of 14
(1,772 Views)
Yes I have read your comment  original folders are not empty.
and I have created destination folders (in the "Destination" tab) and set the destination for the items .
But this folder is still missing in exe and installer
Message 9 of 14
(1,725 Views)
Your folder is inside the executable.
Message 10 of 14
(1,720 Views)
