ERROR 1073676294 ????? VISA READ...!!
Dear All
I am Writing and Reading the data from one EEPROM,interfacing with a PIC16F690,like this i am swiotching 240 EEPROM with MUX,through LabVIEW serial communication pallets,I am controlling the Reading/Writing, but some times ERROR 1073676294 ????? VISA READ...!!,once this error occurs next  all EEPROM chip are not able to READ /WRITE,if unplug the powersupply and plug it back,then LabVIEW can Read/Write,i am not able to fix this error,please advise me whether problem is from LabVIEW or MICROCONTROLLER,I used delay function but also same problem.
Raikar A G
(3,993 Views)
1073676294 is not an error but a warning saying that you got exactly the number of bytes you requested in the Visa read, and that there might be more bytes still remaining in a serial buffer.  (Which I've always considered this a stupid warning, because as a programmer, I'm going to assume that there might be more data in the buffer than I have just pulled out.)
The warning should not cause any problems in your LabVIEW code, nor should it cause a problem with your serial communication.  So if you lose communications with your microcontroller, it must be something else going wrong.
(3,990 Views)
Ya I agree with your point,but my code will not work after this warning message only otherwise its working fine.how to solve this...
(3,984 Views)
We can't help with LabVIEW code unless you happen to actually attach it to your message.
And from my experience, problems with serial communication between LabVIEW and a microcontroller amount to one of two things:  1.  The serial port settings were set correctly to match between the PC and the microcontroller.  2.  A problem within the microcontroller code itself.  VISA handles the most of the nitty gritty details of serial communication for you.  On a Microcontroller, you need to handle that stuff yourself using some arcane functions.  Which do you thing the programmer is more likely to get wrong?
(3,980 Views)
