05-18-2011 11:50 AM
I currently use the M-series 6289 to monitor a few analog voltages. I noticed that it has integrated signal conditioning hardware. How do you enable and setup this up? Is it through S/W or through the H/W?
V/r,
Chris
Solved! Go to Solution.
05-18-2011 09:32 PM
Hi Chris,
Are you talking about the programmable 40 kHz lowpass filter? Here's how to enable it through the API: Programmable Filter on M Series Boards
Or with the DAQ Assistant:
Brad
05-20-2011 06:18 AM
Thank you sir!
