01-17-2012 09:54 AM
I want to build an llb using a previous installer in a project.
There is a '?' beside the installer. When I double click the installer I get the following message:
Error 1059 occurred at Get LV Class Default Value.vi
Possible reason(s):
LabVIEW: Unexpected file type.
Complete call chain:
AB_UI_Initialize_Framework.vi
AB_UI_FRAMEWORK.vi
AB_Item_OnDoProperties.vi
AB_Item_OnDoProperties.vi.ProxyCaller
LabVIEW attempted to load the class at this path:
<Empty Path>
Does anyone know why I am getting this error and how to resolve it?
Sean
01-17-2012 10:05 AM
It looks like you do not have all the VIs defined in your system.
I would use project and bring up that particuliar VI and see what the error list shows up. One thing be careful abl=out classes. I have noticed times when it is erring out (class methods are showing errors), I shutdown labview, and rebooted the machine. After that, the errors disappear.
