Error 1077 Property Node of Multicolumn Listbox
Hello All,
     I've run into an issue where upon trying to grammatically change the selection mode (through a property node) of a multicolumn listbox. When I attempt to change the selection mode from "1" to "3" the program spits out error code 1077 at me.
I'm guessing that this property node is probably just meant to be used as an indicator rather then a control. So, if that's the case I would be grateful to hear any suggestions.
Thank you
(2,380 Views)
Accepted by topic author OJwithPulp
At runtime, you can only change between modes that have the same datatype (scalar vs. array)
(2,362 Views)
