Error compiling examples from DAQmx Base 3.6 on Scientific Linux 6.4 x86_64
I installed NAQmx Base 3.6, and it didn't output any errors, but when I try to make the examples given in /usr/local/natinst/nidaqmxbase/examples/ai, it returns a lot of errors (attached). Is there a way to fix this? I also tried just compiling the files without the make file, but it returned divide by 0 errors.
System specs:
# uname -a
Linux localhost.localdomain 2.6.32-358.6.2.el6.x86_64 #1 SMP Thu May 16 11:21:38 CDT 2013 x86_64 x86_64 x86_64 GNU/Linux
I did notice that nilsdev isn't found. lsmod gives the following:
# lsmod | grep ni
nimxdfk               668960  1
nipxirmk              272550  1
nimdbgk               520774  3 nimxdfk,nipxirmk
nidimk                421013  2 nipxirmk
niorbk                126140  4 nimxdfk,nipxirmk,nimdbgk,nidimk
nipalk               1595877  8 NiViPciK,nimxdfk,nipxirmk,nimdbgk,nidimk,niorbk
nikal                  86684  2 nipxirmk,nipalk
cnic                   55511  2 bnx2fc,bnx2i
uio                    10462  1 cnic
ipv6                  321454  32 ip6t_REJECT,nf_conntrack_ipv6,nf_defrag_ipv6,cnic
What should I do?
Thanks!
(2,581 Views)
The errors look like the system is missing the 32-bit C++ library. Do you have the 32-bit libraries installed [1]?
error.log:
/usr/bin/ld: warning: libstdc++.so.6, needed by /usr/local/lib/liblvrtdark.so.12.0, not found (try using -rpath or -rpath-link)
[1] Unable to Build DAQmx Base C Application on 64-bit RedHat
http://digital.ni.com/public.nsf/allkb/93C92D41B25341B286257A4D007BACB8
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ] [ macOS ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
(2,560 Views)
Oh! I guess I missed the package that provided libstdc++.so.6 when I was downloading the packages from http://digital.ni.com/public.nsf/allkb/93C92D41B25341B286257A4D007BACB8. Thank you so much!
(2,549 Views)
