Error loading vrml file
No I haven't,
And since the support from NI didn't find an answer too, they just ignored me. So I'm sorry but I can't help you guys.
If you're using a portuguese Windows the difference between a dot ( . ) and a coma ( , ) probably is the reason. I managed to get the load vrml working changing one of the subvis.
Message 21 of 23
(721 Views)
Hello guys,
Did you have a solution? The same problem appers when I execute a vi that contains a WRL call. The problem is caused on the parser. I try also with a vrml import tester and the problem remains.
Have you got any idea???
Cheers,
Jai1
Message 22 of 23
(673 Views)
For those having problems with VRML and Labview (which may cause a black screen in 3D Picture Control):
Check your Windows regional settings and change to English. There´s a conflict on how lines with comma or dot are interpreted from VRML depending on the regional setting.
http://digital.ni.com/public.nsf/allkb/862567530005F09C8625677C00751D04
http://forums.ni.com/t5/LabVIEW/Problems-with-the-system-decimal-point-with-german-regional/td-p/181...
Message 23 of 23
(420 Views)
