Errorcode -40 when trying to build installer in LV 8.2
when building an installer of an application I made I get the errormessage listed below (it's in german but the important point can easily be extracted).
The point is: It seems like the builder can't allocate NI-DAQmx 8.8 - which makes sense since it is not installed on my machine. What I don't get is why it tries to include that NI-DAQmx 8.8 in the first place. In the additional installers tab of the installer properties I checked the box for NI-DAQmx 8.5 which is the one installed on the PC. NI-DAQmx 8.8 isn't even listed there. One explanation could be the fact that NI-DAQmx 8.8 was once installed on my PC - but I uninstalled all NI software completely and reinstalled LabVIEW.
Also when I uninstall LV and reinstall it the installer can be built again, but after some time (one day at most) it fails to build again. I haden't made any changes to the LV installation or the build specification meanwhile, but only to the code/vis.
A final note: The obvious fix is to try and install NI-DAQmx 8.8 - and indeed that does let me build the installer. Unfortunately that is not an option because of other issues, it has to work with a plain LV 8.2 installation
Regards
Florian
CDK_Build_Invoke.vi.ProxyCaller >> CDK_Build_Invoke.vi >> CDK_Engine_Main.vi >> CDK_Engine_Build.vi >> CDK_Engine_PromptForMissingDist.vi
Laden der Produktdistributionsinformation
*** Fehler: Interner Fehler. (Fehlercode -40)
Beim Lesen der Information über die Quellendistribution trat ein Fehler bei Produkt 'NI-DAQmx 8.8' auf
*** Ende des Fehlerprotokolls
*** WARNUNG ***
Distributionsinformation für ein nicht identifiziertes Produkt wird übersprungen, da der Fehlercode -40 während des Ladens der folgenden Datei auftrat: C:\Program Files (x86)\National Instruments\Shared\MDF\Manifests\NI-DAQmx 8.8 {B06767E6-7ABE-4E92-A81E-711CD65F813E}.xml
*** WARNUNG ***
*** WARNUNG ***
*** WARNUNG ***
Dateien zu Installationsprogramm hinzufügen
Hinzufügen von Dateien beendet
Vorbereiten zur Erzeugung der Distribution
Produkte von Distributionen kopieren
(2,648 Views)
Hi Xeledon,
try uninstalling DAQmx and then install DAQmx 8.5.
Best Regards,
Andreas Stark
LabVIEW Lead @ Rocket Factory Augsburg
(2,613 Views)
Hi Andreas,
thanks for your suggestion, I tried it immediately.
Unfortunately it didn't help, not even temporarily like un- and reinstalling all NI software does. The error message is just the same.
Any other suggestions? Anyone?
Best Regards
Florian
(2,607 Views)
Does the installer build if you don't include DAQmx?
Andreas Stark
(2,599 Views)
Thanks again for another sensible suggestion I had not thought of myself.
It seems however that I solved the Problem (at least fo now) before I had the chance to put it to the test:
The VIs and the project are on a server and I opened the project from a network drive pointing to the actual place of storage - a bad idea for more than one reason 🙂
After opening the project from its real path (like \\server\etc.) and correcting some entries by hand building works again.
What puzzles me is the seemingly random behavior I experienced before - well not that random, since it always worked after reinstalling LV, but why did it stop working?.
I won't mark this as the Solution yet. Maybe I'll have to report back in the near future with bad news 😉
Best Regards
Florian
(2,590 Views)
