Ethernet/IP Communication Using NI-Industrial Communications for EtherNet/IP 16.0
I could offer you a short MS-Teams meeting on Tuesday or Friday and we could talk about it. If you are interested, please contact me at a.wais@m-a-r-s.de
Message 31 of 34
(356 Views)
Can you explain your VI and also how you determine what sequence of bits to send for your specific command?
Message 32 of 34
(333 Views)
the cip library allows you to access read and write registers, the order is indicated in the smc manual for example:
access word 0 and then bit 0 which corresponds to in0.
it would be easier to explain it to you by video.
Message 33 of 34
(308 Views)
The most important thing would be to know the CIP protocol, how it is encapsulated, TCP/IP and UDP sockets.
to be able to be used in other industrial devices.
smc's equipment is very easy to use, the data transmission required is not that complicated.
The smc equipment is very simple to use, the data transmission required is not that complex compared to a Powerflex drive, kinetix AB or a balluff equipment with io link.
best regards
Message 34 of 34
(306 Views)
