Ethernet IP, initiating session?
Does anybody know when can we expect updated driver EthernetIP.
Explicit communication is too slow, it would be nice if I could initiate an I/O instance for implicit messaging!!
Is there another way to create fast produced/consumed connection with EthernetIP device? using some other libraries or .dll-s?
Thanks!
(3,722 Views)
Ethernet/IP is based on TCP/UDP - you can use the native TCP/UDP functions in LabVIEW and implement the protocol yourself.
According to the page for the Ethernet/IP toolkit - it has an API for implicit I/O data (http://sine.ni.com/nips/cds/view/p/lang/en/nid/209676).
(blog)
(3,709 Views)
If you need speed try packing all of your tags into an assembly, and then use the GetAssemblyInstanceData and SetAssemblyInstanceData VIs. I used this method on a previous project and was able to update data (get and set) every 10ms without issue.
(3,692 Views)
That is correct Labview Addon for EthernetIP support implicit messaging, but only as adapter. It can not initiate session with peripheral device like Beckhoff BK 9055, AB Point IO and other devices that behave like "adaptor".
I thought that if there were some .dll-s for ethernetIP stack-scanner, I could integrate them in LabView like it is done in DAQmx functions. They use .dll-s.
Some operations PLC just can't preform and labview is perfect for that.
(3,657 Views)
