11-27-2007 12:11 AM
11-27-2007 12:26 AM
11-27-2007 12:58 AM
11-27-2007 01:10 AM - edited 11-27-2007 01:15 AM
11-27-2007 03:41 AM
AFAIK, you cannot sort the controls/indicators based on alphabetical [or whatever] order. That belongs to the Case Structure alone, that too only for Numeric cases, I think...
All you can do is just right click on that event case & tell Find Control, thats it; it ll highlight the particular control(s) for that ES.
What purpose you want to achieve by sorting the controls in alphabetical order? Can you explain a bit more?
11-27-2007 04:03 AM
Which version of LabVIEW do you use?
I know that in 8.5 the list order when selecting a local was changed to alphabetical, so it's possible that this also applies now to the event structure list.
P.S. That dialog could stand a lot of improvment.
11-27-2007 04:19 AM
tst,
Also the property & invoke nodes seem to ve been changed to the alphabetical order...!
Or, are they already like that & I missed them all these days?!
11-27-2007 04:27 AM
No, you're right, they also changed in 8.x (I think 8.5). I didn't really get a chance to play with 8.5, but I personally like the older order better, but maybe it just takes getting used to.
11-27-2007 04:35 AM
Cool!
References ve also been changed in 8.5. Moreover the choice of references among several variables are also made like that of choosing a local by simple Lt-click, which was not in 7.1 [only Rt-click -->> Link to was the option like that of Property & Invoke nodes].
If you ve time, check them out, tst.
10-28-2008 05:37 PM
I know that LabVIEW purists will have a cow, and I see that this is an old discussion, but this is what I did.
1. Find the event window the hard way.
1. Find the control terminal corresponding to that event.
2. Replace it with a local variable.
3. Drag the control terminal into the event window.You don't need to connect it to anything. Just leave it there.
Then the next time I need to find that event, I just right-click on the control and select "find/terminal". It saves a lot of time. I suppose it would be nice if LabVIEW had a "find events" option for controls.
