02-12-2016 12:26 PM
This is the information I get from my error handler:
Problem Details:Exception occured in DAO.Database. The query cannot be completed.
Either th esize of the query result is larger than the maximum size of the database (2 GB), or
there is not enoujgh temporary storage space on the disk to store the query result. Help
path is jeterr40.chm, and context in Misc-AddNewRecordActiveX.vi->UUT
database.vi -> Test Executive.vi -> Process Cycle.vi
Microsoft Access has a hard limit of 2GB for a database. The solution, to put off the inevitable a little longer, is to store tables that are continuously adding data in separate databases with one table each and then link to these tables in the main functional database. This delays the database reaching the 2GB limit until one of the individual tables grows that large, rather than all of the tables combined.
This is what I started with:
02/10/2016 04:54 PM 1,265,127,424 Static Inverter ATE DatabaseBackup20160210.accdb
This is the result after splitting out the four data tables, Header, LimitTest, Misc, and PassFail, where I am storing UUT results:
02/10/2016 09:21 PM 226,701,312 Static Inverter ATE Database.accdb
02/10/2016 09:04 PM 3,284,992 StaticInverterATEHeaderTable.accdb
02/10/2016 08:58 PM 380,571,648 StaticInverterATELimitTestTable.accdb
02/10/2016 09:00 PM 540,164,096 StaticInverterATEMiscTable.accdb
02/10/2016 09:00 PM 211,107,840 StaticInverterATEPassFailTable.accdb
Each of the StaticInverterATExxxTable databases contain only one table. Static Inverter ATE Database.accdb contains only links to these tables. Everything worked flawlessly during validation.
Unfortunately, after about 1.5 hours of production runtime on my Test Equipment, it appears that the Misc table grows large enough to cause Microsoft, ActiveX, and or Labview to choke. This is a repeatable situation, like clockwork, every 1.5 hours of active testing. For now, I have reverted to my original database and linked only the smallest table, Header, in an attempt to collect more data. I have definitely made it past the 1.5 hour mark, so this is a size, not timing, issue.
I have attached a couple of the pertinent VIs in this chain.
This PC was new and setup less than a year ago with a clean install of Windows 7, MSOffice 2007, and (unfortunately) Labview 8.6 and has 16 GB of memory. Any clues experts?
02-15-2016 06:37 PM
Just to confirm, you are saying that the Misc table is exceeding 2 GB after ~1.5, causing this crash, and are looking for a way around the 2 GB hard limit of Access databases?
Fortunately, you are not using LabVIEW 8.5... then you would also be contending with a 2 GB max RAM access size as well!
02-15-2016 06:49 PM
I suppose that the MIsc table could be exceeding the 2GB limit. However, 5 years of records and the database containing only the Misc table is only 522 MB. Therefore, I am wondering if the database/table is not being opened and closed properly because I cannot see only 1.5 hours worth of records exceeding the 2 GB limit. When the table is securely tucked in the main database, rather than linked to an external database, this error does not occur.
