11-08-2007 07:27 AM
11-09-2007 01:32 PM
11-09-2007 03:40 PM
I dont know how far this link would be relevant to you.
http://www.lammertbies.nl/comm/info/RS-485.html
Hope it helps.
11-09-2007 03:56 PM
Thanks ! That give me already some answers to my bag of questions.
May be you have one very important answer, before I read thoroughtly all the doc : can I use an RS232 or RS422 com port in connection vith an RS485 device ? What are the caveats ?
11-09-2007 04:55 PM
Well I guess you can. I have personally never used 485. Only thing that i can think of may be that there must be some protection against contention. otherwise standard connections would work unless something is specified for the equipment using it.
http://www.educypedia.be/computer/rs232485bis.htm
This is kind of compiled links here for 232-485. may be this would give you some help. There is an app note in it that will give you some of the answers.also find there a TI note just above that app note. That is a very well compiled info.
Hope it helps.
Ravi
11-09-2007 05:13 PM
To make communications easier with RS485 to labview, I would suggest using a USB to RS485 converter. I've used this converter before and its pretty easy to setup. B&B electronics http://www.bb-elec.com/product_family.asp?FamilyId=357
In the meantime, once you get your USB/RS485 converter you can talk to the MFC using Burkert's communication tool http://www.burkert.com/COM/buerkert_products_new.php?type=8711 (its near the bottom of the page).
11-09-2007 05:43 PM
Iiiike !! LabVIEW vi's
jkho
11-09-2007 05:48 PM
Dravi99 and jkho
Guys, my problems are solved. You have really been of much help. Thanks a lot !
04-09-2017 01:52 PM - edited 04-09-2017 01:52 PM
2007 -> 2017 : Did you find the labview VI for Burkert Mass flow?
