Extract TestStand sequence name and read it in LabVIEW
i need to do a LabVIEW program that reads a .txt file and extract from it certain information that will be used after in a TestStand sequence.
The problem is that this VI must be able to read the name of the sequence is being used in, because this .txt file will have the same name as the sequence (this VI will be obviously used with different sequences, with their specific txt file). How can i do it?
Thank you.
(895 Views)
Accepted by topic author DavideBrusamolino02
Hi Davide,
when you call that VI from your TestStand sequence then you could use the sequence name/step name as a parameter in the VI call…
Is this what you are looking for?
(884 Views)
