FLIR IR camera Silver 420 IR camera
We have a FLIR system's Silver 420 IR camera. We also have some labview vi's to opearte the camera . However, the vi's are not well documented. Has anyone here used labview vi TempCalibration.vi to get absolute temperature measurements from the camera? I need description of the sub vi's especially the one that reads calibration file and another that converts camera digital levels to temperature. It would be great if you have used this vi and could share an example of the absolute temperature masurement using labview vi's and any detailed description on the sub vi's.
Thanks and best regards,
Chander
(2,379 Views)
Hello Chander,
I´ve seen, that the TempCalibration.vi is in a Toolkit from FLIR called ThermoVision LabVIEW Toolkit. Did you get it from there? Maybe there is some more Documentation or Information about that on the FLIR website?
Nina
(2,325 Views)
