FPGA Compilation hangs in "Translating"
Hi there,
when compiling FPGA-Projects on a developing machine, the compiliation does not continue when it's in the translating-process.
There were serveral LabView-Versions installed, so I removed all of them (all National Instruments Software) and did a fresh install of LV2015 32-Bit with RealTime and SoftMotion Module and the needed FPGA-Tools, but this did not solve the error.
I tried another machine (with LV2015) and on this one, everything went fine.
I've checked the logs to see where the error occurs.
Last Xilinx.log-Output on the non-working machine is:
Partition Implementation Status
  No Partitions were found in this design.
NGDBUILD Design Results Summary:
  Number of errors:    31
  Number of warnings: 143
Total REAL time to NGDBUILD completion: 2 min  9 sec
Total CPU time to NGDBUILD completion:  1 min  43 sec
One or more errors were found during NGDBUILD.  No NGD file will be written.
Writing NGDBUILD log file "toplevel_gen.bld"...
After this, nothing happens for at least two hours (I cancelled the last compilation after two hours and started a new one).
On the working machine, the log continues:
Process "Translate" failed
% a bunch of infos
Started : "Translate".
Running ngdbuild...
and the new ngdbuild results are:
  Number of errors:     0
  Number of warnings:  80
Writing NGD file "toplevel_gen.ngd" ...
Total REAL time to NGDBUILD completion: 1 min  46 sec
Total CPU time to NGDBUILD completion:  1 min  39 sec
NGDBUILD done.
Process "Translate" completed successfully
I've attached the complete log file of the working machine.
What can I do to solve this error? I've tried reinstalling Labview serveal times, this already cost me almost two days.
Greetings
Jaifraic
(4,405 Views)
What operating system are you using on the PC that hangs jaifraic? The reason I ask is that the FPGA compilers are not compatible with Windows 8 or 10.
David C
(4,374 Views)
Is that actually true that FPGA doesn't compile with Windows 8 or 10? What would be the solution then?
I am running LabView 2014 with the FPGA and Real-Time Modules installed. I recently tried compiling software after a long time and it is stuck in the 'Translating' Status for more than an hour now.
(4,131 Views)
Use the cloud compilation service provided by NI, or use a virtual (or another) machine running Windows 7.
(blog)
(4,112 Views)
Thanks, @Sam_Sharp. This is turned out to help a lot in addition to upgrading to LabView 2014 Service Pack 1 and all the NI Installer suggested Updates.
(4,093 Views)
