FPGA dynamic read of memory item
I am using a flex rio PXIe-7961R/NI-6585.  When I try to complie my code i get
An internal software error has occurred. Please contact National Instruments technical support at ni.com/support with the following information:
Error -61175 occurred at
Possible reason(s):
LabVIEW FPGA: FPGA FIFO Node not wired with constant FPGA FIFO Name.
I am trying to read from block memory in a subvi that gets a memory name passed into it.  I get the error in the writeTxFifo vi. The tlmMessageBuilder is the calling the vi.  Any ideas on how to fix this problem?
(2,903 Views)
I just took another look at the VI you posted.
The error message you're getting probably has nothing to do with the case structure. The error is a result of using a control as the source of your reference rather than a constant.
(2,866 Views)
