08-07-2012 05:17 AM
Sory if this isn't the correct Board to post this question but I couldn't find a Calibration Executive Board
I'm trying to calibrate a PXI-5610 with the Calibration Executive 3.4.1 and I have the latest drivers instaled on my pc, the probem is that the calibration doesn't start and it gives this error:
"Open VI Reference in cex_Instr_RFSigGen_Init.vi->_NI 5610_RFSigGen Setup.vi->_NI 5610_RFSigGen Setup.vi.ProxyCaller
VI Path: C:\Program Files\National Instruments\Calibration Executive\InstrumentDrivers\LabVIEW\RFSigGen\rssma\cex_Instr_LabVIEW_RFSigGen_rssma_Init.vi
LabVIEW: The VI is not executable. Most likely the VI is broken or one of its subVIs cannot be located. Open the VI in LabVIEW using File>>Open and verify that it is runnable."
What can I do to fix this?
ps: I had to perform the calibration with Calibration Executive 3.2.1 because the client had some urgency...
Can anybody help
Thank's in advance
Bruno Ranhel
08-08-2012 03:20 AM
Hi BRanhel,
Please take a look at this knowledge base. This is for Calibration Executive 3.3.1 but it could work for the 3.4.1
Best Regards,
Vincent.O
National Instruments France
Été de LabVIEW 2014
12 présentations en ligne, du 30 juin au 18 juillet
08-08-2012 03:40 AM
The problem appens before the selfcalibrate, is not a failed value during the calibration!!
09-05-2012 12:48 PM
The problem isn't a fail calibration due to the limits.
The problem is that the calibration doesn't even start!!!
