10-04-2012 12:53 AM
Hello every one .i have an application which uses GE Fanuc QCP1553 card .i m using RT system as BUS controller .The application is working fine but the problem is that when i create exe and set as startup application i m not able to communicate with it host .when i deploy the same application works fine . can any one help me to get out of it ?
06-03-2014 12:54 PM
How do you set up the BC to read the status word from the RT? thanx
06-03-2014 12:55 PM
I had that same problem...had NI here and we could not get it to work...this was 3 years ago or so
