01-31-2017 07:44 AM
Hi all,
is there a way to deny LabVIEW access to certain folders?
I'm currently changing my software from one architecture to another and in the process, certain files may exist twice (I don't want to delete my old work in case I need some of it later on).
So I want LabVIEW to only access my new folder structure with the new VIs, not the old ones. Can I hide/blacklist a folder somehow?
Thanks!
01-31-2017 08:07 AM
Zip, move and/or rename. 🙂
01-31-2017 08:48 AM
You can also Hide the folder (perhaps not in LabVIEW) or make it Read-Only. However, if you use LabVIEW's Recursive File List, this technique might not work, as I think LabVIEW will include Hidden Files. However, this same function does have the ability to include an array of Folders to Exclude, so you could use it to list files and folders except the folder you want to leave alone ...
01-31-2017 02:27 PM
Yup. If you are using source code control feel free to delete it (knowing it is on the server) but you can also zip it up then delete it so LabVIEW can't find it.
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
02-01-2017 02:54 AM
Hi joptimus,
I think zipping your old version should be the way to go right now. To avoid issues like this in the future, I highly recommend using a SSC (source code control) tool to work with different versions of your software.
In LabVIEW you can use this toolkit for that:
http://sine.ni.com/nips/cds/view/p/lang/de/nid/209022
Best,
Jan Göbel
Staff Applications Engineer
