02-11-2020 11:12 PM
Running TEST BOV.vi in the PWC83020_TEST folder will turn off the Labview.
The last DLL function call is a problem, but I'm not sure what's wrong.
I can call other DLL functions without any problem, but I think it's a problem to just input the array as input.
Thank you for any advice.
There is a description of the DLL function in the pwc83020_80.htm file in the doc folder inside the Pwc83020 folder.
04-22-2020 11:04 AM
I had success with this dll in several types of data entry. My LabVIEW is version 2013. Can you save your VI for version 2013 so I can help you?
Because I believe that I can modify your VI with the necessary corrections. I will put explanations within the VI for you to understand what I did.
