Frequency and Amplitude Indicator
@GerdW wrote:
Hi amad,
- You still use that Rube-Goldberg. You can delete that select function safely 😄
- As I can't test the VI (missing DAQmx installation on my computer): did you try to change some of those additional inputs of the "Extract single tone info" function?
When testing the VI with a simple function generator it displays the correct frequency (in the range of 5 to 25 Hz):
you are still not listening.....
Message 11 of 12
(330 Views)
I've kept that function to give the user the ability to enable/disable the control.
Message 12 of 12
(314 Views)
